aaron_do
I understand that VC is the desired common-mode voltage, but i'm a bit puzzled how it actually fits in. When you write VC above the wire, is that supposed to be a voltage source , VC, accross the cap?
Also a bit unsure why you need R when the switched cap is supposed to emulate a resistor...
cheers, Aaron
