Aug 15th, 2024, 11:21am
Problem in display Layout in Cadence 6.1.0 (Read 4342 times)
richard
Mar 20th, 2009, 3:37am
Hi guys
  I met the big problem in displaying layout in Cadence.
what I did show following:
Tools -> Display Resource Manager
> (now in Resource Manager window)
>                Merge -> Ok
>                (now in Merge window)
<your_basekit_dir>/ncsu_basekit/cdssetup/display.drf
>                                Add
Destination DRF: temp.drf
>                                Ok
> Tools -> Library Manager
> (now in Library Manager Window)
>                File -> New -> Library
Directory: <your_homer>/NangateOpenCellLibrary_PDKv1_2_v2008_10/openaccess/
>                                Ok
>                Compile an ASCII technology file
<your_homer>/NangateOpenCellLibrary_PDKv1_2_v2008_10/technology/techfile/virtuos
o/FreePDK45.tf
however, when I opened the layout, it showed nothing except the Metal 1, the details can be found in attachmenet.
Could you please help me out?
Many thanks!
 :D
Re: Problem in display Layout in Cadence 6.1.0
Reply #1 - Mar 20th, 2009, 2:05pm
I'm not really familiar with that design kit - you'd probably be better off going through the support channel for the design kit. I suspect you're not supposed to create a library compiling the tech file, but instead attach or reference a technology library. And I doubt you need to merge the display.drf. But I could be wrong - it depends on how the design kit is setup, I suppose.
Not really a circuit simulator question though  :-/
satheesh
Reply #2 - Mar 25th, 2009, 11:17am
richard wrote on Mar 20th, 2009, 3:37am:
Hi guys
>                Merge -> Ok
>                                Add
>                                Ok
>                                Ok
o/FreePDK45.tf
Many thanks!
 :D
