I'm not really familiar with that design kit - you'd probably be better off going through the support channel for the design kit. I suspect you're not supposed to create a library compiling the tech file, but instead attach or reference a technology library. And I doubt you need to merge the display.drf. But I could be wrong - it depends on how the design kit is setup, I suppose.
Not really a circuit simulator question though :-/
