Jul 16th, 2024, 10:51am
about "port" when simulating mixer without input impedance match (Read 11857 times)
manfred
Mar 21st, 2009, 10:26am
Hi, everyone:
I'm designing a double-banlanced mixer, the input of which is on-chip, so it need not math the input to 50 ohm.  but when I add a port to the gate of mixer input transistor, the amplitude at the gate is twice of my setup in port, e.g. if I fill 1mv of Vpk in port, the pracitcal signal at the gate of input transistor is 2mv.
    of course, the definition of "port" is like this, but when I use this port to drive the high impedance(the gate), the gain result of PXF simulation is 6dB greater than practical value
   I want to know if the NF results of Pnoise simulaiton is right when gain of PXF simulation is 6dB grater?
  How can I do when use port to drive the gate of MOSFET directly?
any reply is appreciate
thanks a lot!
manfred
Re: about "port" when simulating mixer without input impedance match
Reply #1 - Mar 21st, 2009, 9:36pm
You have to show tool's name you use. There are various vendor's simulators.
The followings assumes that you use PSS/PXF Analysis of Cadence Spectre.
manfred wrote on Mar 21st, 2009, 10:26am:
What do you mean by "practical value" ?
The gain result of PXF simulation is parctical value as it's definition even if you use port source for DUT which have high input impedance.
You don't understand definition of various gain. Do you understand definition of gain for PXF Direct Plot ?
You still don't understand the following.
http://www.designers-guide.org/Forum/YaBB.pl?num=1199532619
See the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1202753208/13#13
http://www.designers-guide.org/Forum/YaBB.pl?num=1122952471/5#5
http://www.designers-guide.org/Forum/YaBB.pl?num=1215827287
I want to know if the NF results of Pnoise simulaiton is right when gain of PXF simulation is 6dB greater?
It is right. Learn definition of NF.
See the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1214890959/2#2
http://www.designers-guide.org/Forum/YaBB.pl?num=1215826972
http://www.designers-guide.org/Forum/YaBB.pl?num=1194006190/2#2
You have to learn measurements using actual instruments. Not "EDA Tool Play".
http://www.designers-guide.org/Forum/YaBB.pl?num=1233236788
If you are familiar with actual measurement using actual instruments, you will never use Direct Plot of Cadence ADE blindly.
Of course, I don't use Direct Plot of Cadence ADE. Indeed I don't use SpectreRF itself for RF circuit design.
« Last Edit: Mar 22nd, 2009, 10:05am by pancho_hideboo »
manfred
Reply #2 - Mar 22nd, 2009, 4:01am
thanks pancho_hideboo!
yes, the tool I used  is cadence spectreRF.  "the practical value" is the right gain from  transient simulation or pss simulation, which i think is right. how do you think about it?
the gain in my mixer should be voltage conversion gain, it have no input impedance match, but in order to run NF simulation, I add "port" to the input of mixer( gate of mosfet).
about  6dB  greater than the true voltage conversion gain, I think it is caused by vout/E ( E is my setup in port), but in reality, the signal at the gate of mosfet is 2E, so the gain from PXF is 6dB. is it right?
but I still wonder about the true NF. if I parallel a 50 ohm resistor to the port , I can get the right conversion gain from PXF, but the NF from Pnoise is not right, because the resistor introduce extra 3dB noise.
so , can you tell me how should I do in order to get both the right gain from PXF and right NF from Pnoise?
thanks for your patience!
Reply #3 - Mar 22nd, 2009, 4:24am
You seem to have no experience of actual measurement at all.
manfred wrote on Mar 22nd, 2009, 4:01am:
Maybe your gain definition of PSS and Tran is Vout/Vin.
You don't understand various voltage gain definitions.
   Gain definition of Direct Plot is same for PAC, PXF and Pnoise, which is not Vout/Vin.
   Gain definition of PSP is Vout/Vin.
   S21 is another voltage gain.
All these gain are "right" and "true" voltage gain.
Actual NF meter give gain and NF values at same time.
Do you understand definition of this gain ?
about 6dB greater than the true voltage conversion gain, I think it is caused by vout/E (E is my setup in port),
Correct. But it is never 6dB. And an expression of "the true voltage conversion gain" is not proper.
Gain from PXF is also true voltage conversion gain.
If you dare to refer Vout/Vin with some name, you should call it as general or common voltage gain which is used for low frequency circuit.
It is a little wrong.
Input impedance of DUT is not infinite actualy. For high frequency it is capacitive at least.
So It is never 6dB actually.
Your usage of symbol "E" is not common.
Generally "E" is used like following.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1122952471/2#2
Your usage Quote:
Common usage Quote:
I think it is caused by vout/(E/2) (E/2 is my setup in port)
the signal at the gate of mosfet is E
Not correct. It is not right gain at all.
Again input impedance of DUT is not infinite actualy. For high frequency it is capacitive at least.
You are completely wrong.
You can't get even correct general voltage gain in your method. Of course you can't get correct NF.
You don't seem to understand RF basic theory at all. You should read text book on RF Basics.
so, can you tell me how should I do in order to get both the right gain from PXF and right NF from Pnoise?
If you want to calculate Vout/Vin, use one from the following three methods.
(1) Don't place 50 ohm resistor parallel to port. Invoke PSS/PAC/Pnoise.
About NF, use Direct Plot for Pnoise.
Calculate Vout/Vin from PAC without using Direct Plot.
(2) Don't place 50 ohm resistor parallel to port. Invoke PSS/PSP.
You can Calculate both NF and Vout/Vin from PSP by using Direct Plot.
(3) If you want to insist on using PXF, place 50 ohm resistor of noiseless parallel to port and use VCVS to drive DUT. Invoke PSS/PXF/Pnoise.
You can calculate both NF and Vout/Vin by using Direct Plot.
But I never use this method especially for mixer. See the following.
http://www.designers-guide.org/Forum/YaBB.pl?num=1231854969/5#5
Indeed I don't calculate Vout/Vin since we can't measure Vout/Vin in actual measurement.
I calculate different voltage gain which is matched to definition of actual measurement.
Many Cadence Tool Players have same confusions as you have.
This is due to no experience of actual measurements of Cadence Tool Players.
On the other hand, Agilent Tool Users(not Players) never have confusion for such too basic issues since almost of them have experience of actual measurement.
Again, you have to learn measurements using actual instruments. Not "EDA Tool Play".
I'm not kind and patient enough for explaining such too basic issues.
If you can not still understand, other people who is very kind and patient will help you.
« Last Edit: Mar 22nd, 2009, 10:16am by pancho_hideboo »
