Aug 17th, 2024, 10:19am
low voltage switched capacitor filter (Read 2743 times)
manodipan
Apr 30th, 2009, 5:03am
Hi guys,
Actually i am designing some low voltage SC filter.....so the sampling stage is stray insensitive bottom plate sampling...my question is that i am simulating by connecting voltage source directly to the sampling stage......do i need to put some buffers also pin parasitics will also come into picture....so i want clarification s on that as otherwise i have to use low voltage opamp in unity gain configuration....thanks a lot...
HdrChopper
Re: low voltage switched capacitor filter
Reply #1 - May 7th, 2009, 7:20pm
Hi manodipan,
Whether you need a buffer before the sampling stage or not will depend on the actual output impedance of the circuit driving your sampling stage. IF such impendace is not too large then as long as you guarantee that during the sampling time the signal will fully charge your sampling cap then it should be ok.
Otherwise you might need to use some sort of buffering.
Hope this helps
Tosei
Keep it simple
raja.cedt
Reply #2 - May 8th, 2009, 1:23am
hi manodipan,
                      i don't see any advantage of putting buffer,in fact it will add some noise and power dissipation at the same time the bandwidth should be grater than your sampling frequency and  you may not sample with sampling frequency what you want to be.As you said it is low voltage then designing op amp also big challenge. As an experiment you can use an VCVS and op amp buffer ..you will see increased integrated noise in case of op amp buffer.
Rajasekhar.
Berti
Reply #3 - May 8th, 2009, 3:51am
Rajasekhar,
I don't understand your comment:
Quote:
i don't see any advantage of putting buffer,...
As Tosei wrote, I also think that it depends on the driving circuit whether you need an additional buffer or not.
If it is a prototype circuit (stand-alone test circuit), I would recommend to take a look at the bondwire inductance and parasitic capacitances to make sure that the ringing decays fast enough.
Cheers
