hi all,
does any one has a circuit idea of how to realize a voltage controlled current source?
the obvious solution is to use a resistor and an op amp in feedback but then I have 20% variation (actually more with the process I am using) witch is very high.
in principle I can give up linearity for a more process independent current source ...
maybe some simple self calibration ideas ?
any comment would be helpful
thanks
