Jul 16th, 2024, 2:43pm
dBm option in Cadence Waveform window provides funny results !! (Read 70 times)
AnalogAroma
Jul 26th, 2009, 7:09am
Hi Everybody,
       I have calculated the psd of a periodic signal with psdbb function from the Calculator -function menu. The psdbb function provides  rms-squared output. When I change the scale of the curve to dBm , I get very strange results.
One example is that psdbb gives a value of 323.4 u at 101.6KHz. Using the dBm formula , the dBm value should be -21.89 dBm. But, if you use cadence dBm scale, you will get -4.902 dBm. The diffrence is equal to 10 log 50 !!
It looks like Cadence use 1 ohm to calculate dBm !!!!!!!!!!!
