Aug 15th, 2024, 7:23pm
Multi-carrier simulation (Read 5896 times)
sandman
Nov 02nd, 2009, 2:04am
I'm trying to simulate worst case PAPR for a multi-mode tx which can simultaneously tx combinations of GSM/EDGE, WCDMA/HSPA and LTE.
The carriers could be any combinations of GSM carriers (>1), WCDMA (>1) and LTE carriers, in the same band.
I have a setup for MC-WCDMA (MC=MultiCarrier) running in ADS and I can perform measurements like CCDF (and very soon ACLR) on the combinations of carriers.
However, I'm trying to figure out if anyone has any experience on co-simulation MC-GSM, MC-WCDMA and LTE on the same template and if they could provide some advise on the same (do's, don't's etc.)?
Any input are welcome!!
Cheers!
Re: Multi-carrier simulation
Reply #1 - Nov 3rd, 2009, 5:26am
sandman wrote on Nov 2nd, 2009, 2:04am:
I can't understand what your questions are.
Please describe your question in detail.
sandman
Reply #2 - Nov 5th, 2009, 2:03am
Sorry, reading that again, it does sound a bit unclear to me too.
Anyway - I'm trying to simulate a multi-mode transmitter chain. I need to be able to generate signals of multiple carriers of each  - GSM/EDGE and WCDMA/HSPA, and LTE together (i.e. on the same design schematic, if that is possible). I'm trying to measure the combined PAPR (via CCDF) of all of these carriers together.
If it is not possible to simulate it together, I'd like to be able to generate them seperately and then add them together, so it appears like I'm transmitting all of the above signals through the same RF+Baseband transmit chain.
Essentially, I'm trying to see what my multi-mode transmitter spec. would need to be, if I tx GSM/EDGE, WCDMA/HSPA and LTE carriers at the same time, if that's possible at all.
Is this possible in ADS or Matlab ? If not, why and if yes, how - what kind of sampling rates will I have to use, what kind of filtering will I need to use etc. ?
Hope that gives more detail.
Reply #3 - Nov 8th, 2009, 12:29am
Why do you post in RF Simulators ?
Is there any relation to RF Simulators ?
sandman wrote on Nov 5th, 2009, 2:03am:
Not improved at all.
Still no one can understand a meaning of your sentences.
What do you mean by "the same design schematic" ?
DUT's schematic ?
Full Testbench schematic including DUT and Vector Signal Analyzer ?
You mean that you want to generate one combined signal of three mode signals with different carriers by only one DUT ?
Show me your diagram of measurement using DUT and actual instruments such as Vector Signal Analyzer.
Learn measurements using actual instruments. Not "EDA Tool Play".
What do you mean by "I'd like to be able to" ?
You mean that you want to combine three mode signals with different carriers by power combiner and three DUT ?
I can't understand what you mean.
I can understand "the same RF".
However what do you mean by "Baseband" ?
You mean DAC and programmable Digital Filter ?
Or only DAC with other all signal processing by DSP ?
MATLAB are different from Simulink.
Do you mean truely MATLAB ?
I can't understand your questions.
But I think it is possible using any of Agilent Ptolemy, Agilent SystemVue, Mathworks Simulink, CoWare SPD(SPW), etc.
I recommend you to use Agilent SystemVue not Agilent Ptolemy.
Currently main stream of ESL(Electronic System Level) design tool of Agilent is SystemVue not Ptolemy.
I can't expect any progress of Ptolemy any more.
Your sentences are too poor and your questions are too vague.
Your schematic includes only behavioral model ?
What do you mean by "filtering" ?
There are many filtering used in Transmitter signal path.
Where is location of "filtering" in Transmitter signal path ?
The followings are general notes.
- Use correct terminologies.
   - Warnigns are different from Errors.
   - ADS is not name of simulator.
   - There is no tool which name is Cadence.
   - All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
   - MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play".
« Last Edit: Nov 8th, 2009, 5:58am by pancho_hideboo »
sandman
Reply #4 - Nov 8th, 2009, 6:23am
Quote:
sandman: pancho_hideboo, Perhaps my use of generalisations was ambiguous, so I'll try to clarify it again for everyone's benefit, assuming, like you no one else here understood my questions.
Like I wrote and to explain further, I'm trying to design a multi-mode transmitter (to be extended to multi-band later) which is capable of simultaneously transmitting GSM/WCDMA/LTE signals, using the same RF components - MCPA, VGA, IQ-Modulator etc.
For this I need to be able to generate signals in a software simulation environment, in order to study certain aspects of the combined signal waveform, in time and frequency domain - this, so that I can understand what the requirements of my multi-mode transmitter should be - peak power (via CCDF), spurii etc.
With some level of generality, this could either be done in Agilent (Ptolemy or SystemVue) and Matlab/Simulink, or possibly using hardware equipment such as a signal generator (ex. from R&S SMU200A) and vector analyzers. But how are the signals combined best? Does a single Sig.Gen. exist which generates all internally and provides a multi-mode signal at the RF port of the Generator or does one have to use seperate Sig.Gen.s and combine them using a combiner and some filtering?
Since the above signal types have symbols which have different properties in time domain, some amount of attention needs to be given how a signal that is a combination of GSM/WCDMA/LTE waveforms are sampled, and therefore equal attention needs to be given to interpolation (i.e. DSP filtering)
Quote:
sandman: Not sure I understand why and how this highlighted stmt. is relevant here.
Quote:
sandman: Again, not sure how this can not be understoof, even if vaguely.
Quote:
I'm not sure how these signals are combined best, in the harwdare domain which is why I asked this question to the forum.
Quote:
sandman: By RF I mean, the same RF components which support convergent, simultaneous multi-mode transmission. I'm not comfortable yet with baseband terminology, so yes, if you mean DAC+DSP, then I think that would probably agree with that.
Quote:
sandman: Thanks! I was considering Ptolemy because I have a multi-carrier WCDMA simulation setup in Agilent Ptolemy to measure CCDF (i.e. design schematic, which will later include other measurements like ACLR etc.), but was not sure how to add GSM/EDGE and LTE carriers to this schematic, i.e. what factors to pay attention to, when combining multi-mode carriers.
Quote:
sandman: Like everyone else who's learning from this open forum, I appreciate experienced members who share insightful remarks for the benefit of everyone, not disconnected rants possibly a carry over from other posts and interactions. Nevertheless, I greatly appreciate your and everyone else's technical comments. I would be happy to clarify my question further if it is challenging to understand...
Reply #5 - Nov 8th, 2009, 6:34am
sandman wrote on Nov 8th, 2009, 6:23am:
It depends on carrier separation, modulation bandwidth and required ACPR(ACLR).
If you use enough broad Vector signal Generator and both carrier separation and modulation bandwidth are not so wide and required ACLR is not so large, you can generate multi-carrier signal by using only one Vector signal Generator.
It is also very true for simulation costs and efficiency.
Simply it is required total system bandwidth issue and required DAC resolution issue.
About latter, you don't have to care about DAC resolution in Simulation Domain if you use double precision expression without quantization.
pancho_hideboo wrote on Nov 8th, 2009, 12:29am:
Read my comment above.
Simulation Domain is very related to actual Measurement.
If you can understand actual hardware or actual instruments correctly and properly, strategy of simulation is straight forward.
Simply, expression issue.
I can't understand difference between "I'd like to" and "I'd like to be able to".
Good Luck.
« Last Edit: Nov 8th, 2009, 9:24am by pancho_hideboo »
