Jul 18th, 2024, 12:23am
speed up the NCsim elaboration process? (Read 1762 times)
ln3
Mar 19th, 2010, 3:59am
Hi there
I am currently simulating the Top level of a mixed signal chip. The digital parts are synthesized verilog netlist and the analog part has been completly modeled using Verilog-AMS. Currently, we are using IUS/Incisive 92.
Since the digital part in the testbench wont change, is there anyway to speed up the elaboration process?  can't find any ncelab command for that.
Thanks in advance for your help!
Re: speed up the NCsim elaboration process?
Reply #1 - Mar 19th, 2010, 10:58am
Which flow are you using (OSS/irun or CellBased/three-step (ADE or HED))?
The elaboration is much quicker using the irun flow.
You don't give much info - how long is it spending in elaboration?
More of a tool issue - this probably would have been better in the AMS Simulators board (I suspect Ken will move it there).
ln3
Reply #2 - Mar 19th, 2010, 11:28am
Andrew Beckett wrote on Mar 19th, 2010, 10:58am:
Thank you for the answer Andrew.
Currently I am using HED  Cell based three step flow, elaboration took almost 15 min to finish and is not really multi core capable. I have changed OSS/irun in the ADE one time, but it throws me a netlist error event the netlist log shows no errors....
Reply #3 - Mar 21st, 2010, 3:43am
One way to make the conventional three-step elaboration quicker is to limit the number of libraries in your cds.lib (not always possible).
Anyway, I'd suggest you contact Cadence Customer Support - that way we can work through this carefully and with the full information of what  you're trying to do (and file a CCR if there's a bug or enhancement needed).
ln3
Reply #4 - Apr 9th, 2010, 8:05am
Hello Andrew,
THank you very much for the replies. Using the OSS based netlist do give me some speed ups, but the oss netlist and ncvlog has problem with modules using  2-D arrays like
module test(\out1[5])
output [3:0] \out1[5]
is ther any work around for this?
Reply #5 - Apr 11th, 2010, 8:05am
That looks very odd - I'm not sure why such a net name would be escaped. Without knowing what the design looks like and which version you're using, hard to know the root cause and if there's a fix or workaround.
I would suggest you contact Cadence Customer Support.
