Jul 17th, 2024, 12:31am
Pole analysis differ from theory (Read 6576 times)
supermoment
May 08th, 2010, 12:16am
I built common source amplifier  by using a single nmos transistor  with ideal 1k ohm load (Rd), bulk tied to ground (no body effect). Bias Vgs at around 0.7V and do AC simulation & pz analysis
width = 10um x 4 finger ; length=0.18u ; vdd=1.8V
Result from pz analysis
Pole1=-4.582GHz
Zero1=70.72GHz
AC measurement:
Av_DC=17.49dB
Av_DC=7.486 V/V
3dB_BW=4.753GHz
Extracted intrinsic cap of the nmos
gm=8.791m
Cdg=-19.78f
Cdb=-2.23f
Cds=11.28f
Csg=-26.51f
Csb=-3.342f
Csd=-23.11a ~0
Css=29.88f
Cdd=10.73f
Cgg=49.37f
Cgd=-10.72f
Cgs=-33.81f
Cgb=-4.849f
From theory,
Av_DC=gm*Rd=8.791m*1k=8.791 vs simulated 7.486
poles=1/(2*pi*Rd*(Cdg+Cdb)=1/(2*pi*1k*(19.78f+2.23f))=7.23GHz
vs simulated pz analysis=4.582GHz (huge difference)
3dB_BW = 4.753GHz
I try to relate simulation result with theory.
If back calculated from pz analysis
Cload=1/(2*pi*f*Rd)=1/(2*pi*4.582GHz*1k)=34.73fF
which is very near if Cload=Cdg+Cdb+Cds=19.78f+2.23f+11.28f=33.29f
however Cds is different sign with Cdg+Cdb...
Hope someone can clarify it...
it should be simple...but cant reach it..
supermoment
Re: Pole analysis differ from theory
Reply #1 - May 8th, 2010, 12:19am
Does overlap capacitance Cgdovl factor into the Cgd and Cgsovl factor into Cgs?
Reply #2 - May 8th, 2010, 3:41am
What simulator do you use ?
Do you use Synopsys HSPICE which is "Golden Standard Simulator" ?
The followings are general notes for you.
- Always describe correct tool's name and vendor's name which you use as tool or simulator.
- Don't do multiple posts which are same content.
- Don't request source code or behavioral model without any efforts.
- There are many simulators which have analyses called as PSS, PAC and Pnoise.
- Describe in detail with using correct terminologies.
- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
supermoment
Reply #3 - May 8th, 2010, 3:56am
using Cadence, spectre simulator.
(do not have synopsys, Yes i know HSPICE is golden standard)
Is the discrepancy because of the PDK accuracy? I am not sure. Because I found weird BW result in other circuit. That's why i constructed a simply testcase, common source amplifier
Av_DC_dB  --> value(dB20((VF("/out") / VF("/vgs"))) 1 ?histoDisplay nil ?noOfHistoBins 1)
Av_DC  --> mag(value((VF("/out") / VF("/vgs")) 1 ?histoDisplay nil ?noOfHistoBins 1))
3dB_BW --> bandwidth((VF("/out") / VF("/vgs")) 3 "low")
where vgs is input with small signal acm=1mV, out is output node
the gm & Cxx are obtained from OP (in dc)
Reply #4 - May 8th, 2010, 7:20am
I think result of Cadence Spectre PZ analysis is reasonable.
Maybe there are some issues in interpretation of results of DC operation point information.
supermoment
Reply #5 - May 8th, 2010, 7:26am
pz result is almost same with AC response curve.
The thing i doubt is the extracted capacitance by using OP
the values seems smaller...
could someone compare those extracted cap with other simulator or foundry in 0.18um technology?
supermoment
Reply #6 - May 8th, 2010, 7:34am
one more query, why Cds is not counted in freq analysis. source is grounded, so Cds can be part of the load at drain load.
I have checked  few textbooks, Cds is not counted. Is it because it is too small?
supermoment
Reply #7 - May 9th, 2010, 8:25pm
Found out that Cds splits into Cgb, Csb, Cdb...
therefore Cds is not counted since Cdb is already taken in.
raghu_n_ch
Reply #8 - May 25th, 2010, 7:52am
Are you accouting for device rds.
There will be miller multiplication of the cap Cdg depending on the gain, this also needs to be considered.
