Jul 17th, 2024, 2:34am
transfer function... (Read 1239 times)
somisetty
May 05th, 2010, 10:35pm
hi
can anyone tell me how to find the transfer function..the procedure for the given circuit attached..
is the gain in this case a ratio of vcomp/(vref-vout) ?
thanks a lot...
Re: transfer function...
Reply #1 - May 6th, 2010, 4:20am
Somi,
  If you have access, you might want to try looking at Chapter 3 of
"Switch-Mode Power Supplies" by Christophe Basso. Chapter 3 provides
detailed discussion of the controller transfer function. The topic is
also covered in "SMPS simulation with SPICE3" by Steve Sandler
as I remember.
raja.cedt
Reply #2 - May 10th, 2010, 9:51pm
hi,
   that is the gain from Vcomp/Vout...because Vref is bias, so how can you take into consideration while calculating gain?
thanks,
Rajasekhar.
buddypoor
Bremen, Germany
Reply #3 - May 11th, 2010, 2:13am
More than that, since the opamp has no dc feedback, the ref. voltage will be amplified by a factor of 1E4---1E5 (dc gain). Even if Vref=0 there will be still an offset problem due to lack of resistive feedback - unless, the circuit is part of an overall stabilizing feedback loop.
raja.cedt
Reply #4 - May 11th, 2010, 7:47am
ya buddy poor,
                     what you have said is correct..i guess this is a part of an controller, so it can stabilize overall _ve feedback..thanks for mention that
Rajasekhar.
AdrianSN
Reply #5 - May 23rd, 2010, 11:05am
This is an error amplifier used in controllers.  Here is how to derive the transfer function:
First, bring R2, C1 and C2 under one component, Z2.  R2 is in series with C2 and both in parallel with C1.
Z2 = ((R2+(sC2)-1)-1+sC1)-1
The amplifier becomes a differential amplifier in AC, with the components in the non-inverting input removed.  The transfer function is:
VCOMP=REFERENCE*(1+Z2/R1)-VOUT*Z2/R1
The differential amplifier transfer function is explained here:
http://masteringelectronicsdesign.com/the-differential-amplifier-transfer-functi....
