Aug 3rd, 2024, 11:17pm
about fully differential opamp (Read 1383 times)
lhlbluesky_lhl
Sep 26th, 2010, 7:43am
for a fully differential opamp, how to simulate its PSRR, CMRR, ac noise, CMIR, output swing, etc, in ellen's book, i can find the simulation methods for single-ended opamp (for the above parameters), but what for fully differential opamp?
besides, for ac noise simulation of fully differential opmap, there are two input ports which include ac signal (Vin+: ac=1V, Vin-: ac=-1V in my case), so, is the ac noise measured in Vout+ node or Vout- node or for both Vout+ and Vout- node? in another word, the ac noise for fully differential opamp is two times as the same single-ended opamp, am i right? if not, please correct me.
finally, how to measure the CM gain of fully differential opamp? as we know, CMRR=Av,DM/Av,CM, so i want to get the CM gain for my fully differential opamp. and how to measure the CM gain of single-ended opamp?
thanks all for reply, thanks all.
