Jul 28th, 2024, 11:19pm
how the number of harmonics in PSS affects PAC simulation? (Read 2172 times)
sapphire
Jan 20th, 2011, 7:30pm
I want to simulate the supply rejection of my regulator using PAC. The regulator is used to provide a clean "supply" for ring osillators in a PLL. This is only a standalone simulation containing only regulator, oscillators, and some bias circuits.
Since I am only interested in the harmonic index=0 output frequency response, can I set the number of harmonics in PSS simulation to 0? This saves me a lot of time and it's much easier to get convergion. I think noise folding is not the case here, so higher harmonics wont contribute to the PAC accuracy. Please correct me if I am wrong.
Sapphire
Re: how the number of harmonics in PSS affects PAC simulation?
Reply #1 - Jan 21st, 2011, 11:16pm
If using shooting, then the answer is yes, you should (in general) be able to set the number of harmonics in the PSS to 0. This is because there will be timepoints following the waveforms regardless of the number of harmonics requested, and the minimum number of timepoints produced is based on ensuring spectral accuracy up to 4 times max(maxHarmonicRequested,10).
If using harmonic balance, you'll need to ensure you've requested enough harmonics in the PSS to ensure that it can accurately represent the PSS solution in a frequency domain representation of the solution. So 0 would definitely not be OK then!
Andrew
