I presume you're not actually using RapidIP3, because that would be done using PSS (with just LO enabled) and then PAC in RapidIP3 mode.
Without knowing what the behaviour of the circuit is, and what the spectral response is, it's very hard to give generic guidelines. I think you'll need to give some more details, and probably some pictures of the response you're getting from QPSS and QPAC.
