Jul 31st, 2024, 7:14pm
Simulating Frequency Response for Differential Ring Oscillator (Read 3543 times)
ic_engr
May 07th, 2012, 11:41am
I would like to know how we can simulate the Freq Response of a ring oscillator which is differential.
Where would I break the loop to get Open loop Gain since its differential input/output ?
ic_engr
Re: Simulating Frequency Response for Differential Ring Oscillator
Reply #1 - May 7th, 2012, 6:25pm
IC_Engr,
  Not sure what you are trying to do. Do you just want the open loop
frequency response, do you want to know the closed frequency
response, or do you want to analyze stability? The answer changes
depending on your answer.
ic_engr
Reply #2 - May 8th, 2012, 7:58am
Sheldon,
I would like to do both Open Loop and Closed Loop Freq Response.
Any suggestions ?
Abdullah
