Jul 30th, 2024, 7:18am
Sigma-delta ADC: Matlab sims vs Spice sims. Odd harmonics (Read 2922 times)
hoss
Tokyo, JPN
May 25th, 2012, 1:23am
Hello all,
I am currently trying to design the analogue part of a 2nd-order sigma-delta ADC. My bandwidth is 1KHz and I need to achieve SNDR > 98dB (16bits).
I have started with some Matlab-Simulink simulations base on the SigmaDelta Toolbox. The only non-desired effect I am considering so far is just the switch non-linearity and the KT/C noise. Both integrators are ideal and there is no saturation in the system.
I have implemented the same system in my spice simulator. Ideal integrators and comparator.
When simulating both systems under same conditions, I have found that the schematic simulation has odd harmonics, which are not visible with Simulink. These harmonics ruin my SNDR so results are different from expected.
I have seen other people having the same issue as me but, I still don't know where these harmonics come from or how to reduce them.
Even with ideal components, are odd-order harmonics a common issue in SD-ADCs?
Thank you in advance to everyone providing some feedback.
