bki
i never worked with Verilog-A before and now i try to add a model in cadence. I always get errors that i don´t really understand. Maybe someone can help me to correct the model. It should be a 2 Input AND Gate.
Thats the Code: `include "constants.vams" `include "discipline.h"
module V_and(in,out); parameter real size = 2 from [2:inf), vout_high = 5, vout_low = 0 from (-inf:vout_high), vth =1.4, tdelay = 5n from [0:inf), trise = 1n from [0:inf), tfall = 1n from [0:inf);
input[0:1] in; output out; voltage in,out;
integer in_state[0:1]; integer out_state; integer i; real vout;
analog begin @(initial_step) for(i=0;i<2;i=i+1) in_state[i]=0;
generate i (0,1) begin @(cross(V(in[i])-vth)) begin in_state[i] = V(in[i])>vth; out_state=1; for(i=0;i<2;i=i+1) if(!(out_state && in_state[i])) out_state=0; if(out_state) vout=vout_high; else vout=vout_low; end end
V(out) <+ transition(vout,tdelay,trise,tfall); end endmodule
The Errors are: Line 35: "@(cross(V(in[i]<<--?)-vth))" : Identifier ("in") is neither and array nor a vector. Declare identifier as an array or a vector. :The node array access is out of range. Correct the problem.
Line 30: Encountered an invalid assignment during `generatre`or `genvar`unrolling. Check the validity of the genvar variables.
