Jul 20th, 2024, 5:23am
Basic Question : NMOS Switch on-resistance Versus Input Voltage Figure (Read 3573 times)
allenhan
Sep 29th, 2015, 9:31am
It is quite a basic question, I wanna draw the nmos switch on-resistance versus the input voltage figure. Here is what I have done so far. nmos gate is 3.3V, and the input voltage is a DC sweeping voltage ( I suppose it is from 0 to 3.3V), and the at the output node of the nmos, I put a holder cap to the ground also. So based on this model I wanna draw the Ron VS. Input Voltage figure.
I tried to use the XL calculator to calculate it, like, Ron =( Vin-Vout )/In,  but compared to the real value in the DC operating point report,  the calculator doesnt give a good number. and also which is strange, the when input is 500mV, for example, I plot the S node and D node current of nmos, but the currents are not same.....confuse me.
Any way, I think I saw some options on web, but not really accurate and neat, so I want to ask again, is there a good way, in cadence to draw the continuous figure line Ron VS. Vin.   Thanks.
RobG
Bozeman, MT
Re: Basic Question : NMOS Switch on-resistance Versus Input Voltage Figure
Reply #1 - Sep 30th, 2015, 7:48am
Are you applying an "In" or just looking at leakage? How much is the difference between the source and drain current?
I apply an Iin using a DC current source so that Vds is ~10mV then plot Vds/Iin. You could also do a parametric sweep and plot gds using the OP function in the calculator.
DanielLam
Reply #2 - Oct 1st, 2015, 11:36pm
This page has the setup for Ron. I've used it hundreds of times. Look for on-resistance of a switch. You can do a parametric sweep of W/L versus Vcm.
If you get an impedance, take the real part of it to get resistance.
http://web.engr.oregonstate.edu/~moon/kaj/cadence.html
Reply #3 - Oct 5th, 2015, 7:54pm
Why don't you just plot input voltage against the gds value, the
real value, from the dc operating point? Right now, you are just
dividing 0/0.
A Kumar R
India
Reply #4 - Oct 6th, 2015, 1:38am
Can you give a drawing of what you are trying to do? i am not getting where is Vin , Vout and all those notations you have used.
Anil Reddy
