You'll need to provide some context. This is the kind of information you'll need to provide to allow anyone to help: - What does the circuit look like that you're analysing (pictures or even better a netlist would be good)
- You posted this in the physical verification and extraction forum, so what tool are you using to extract the circuit?
- What simulator and version are you using?
- How are you simulating this? What analysis, what setup?
- What do the results look like that you think are problematic?
Your question as it stands is too lacking in detail to be able to answer, other than me suggesting you speak to your supervisor... Andrew.
