Jul 21st, 2024, 11:21pm
SAR ADC Cadence to Matlab (Read 941 times)
repah
Nov 29th, 2018, 11:30am
I am designing a SAR ADC in Cadence Virtuoso/Spectre and want to export the output of the DAC to MATLAB.
Is there a way to automate this in Cadence Virtuoso - a file write block in Verilog-A ?
Is this publicly available, included in Virtuoso or available somewhere else ?
Any tutorials about this available ?
Thank you.
DanielLam
Re: SAR ADC Cadence to Matlab
Reply #1 - Nov 29th, 2018, 12:29pm
I suggest looking into Matlab Spectre Toolbox. You can directly pull the Cadence output data from Matlab with the cds_srr command.
The support website has examples, although it is a little hard to read. In the end, it requires a bit of trial and error to get the syntax right.
Otherwise, you can write outputs with an ocean script. I used to do this until I learned about the Matlab Spectre Toolbox.
