DanielLam
I suggest looking into Matlab Spectre Toolbox. You can directly pull the Cadence output data from Matlab with the cds_srr command.
The support website has examples, although it is a little hard to read. In the end, it requires a bit of trial and error to get the syntax right.
Otherwise, you can write outputs with an ocean script. I used to do this until I learned about the Matlab Spectre Toolbox.
