Aug 17th, 2024, 12:21pm
Analog and Mixed Signal Design Flow (Read 6713 times)
flip_flop
Ex Member
Sep 15th, 2002, 3:46pm
I like Ken's paper
http://www.designers-guide.com/Design/top-down.pdf. However, for complicated mixed signal designs, probably it is worth to develop soft and hard macros, IP re-use, and so on (in order to speed up development.) So it will be not pure top-down design. Say, digital designers have advanced methodology, based on the IP re-use, Virtual Socket Interface (VSI), etc. They put well established rules in "Reuse Methodology Manual for System-On-A-Chip Designs" (by Michael Keating, Pierre Bricaud). Also the VSI site (http://www.vsi.org/) is very comprehensive.  Do we have some similar documents/papers in the analog and mixed signal design emphasis? Thanks.
  IP Logged
Re: Analog and Mixed Signal Design Flow
Reply #1 - Sep 15th, 2002, 10:38pm
I'm not aware of much that is available. There is a bit in http://www.designers-guide.com/Design/MS-SOC.pdf, and you might find something in ...
  • H. Chang, E. Charbon, U. Choudhury, A. Demir, E. Felt, E. Liu, E. Malavasi, A. Sangiovanni-Vincentelli, I. Vassiliou, A Top-Down,Constraint-Driven Design Methodology for Analog Integrated Circuits, Kluwer Academic Publishers, 1997.
I don't think anybody is doing anything with soft IP for mixed-signal circuits, nor do I expect anybody will for a long time.
Henry Chang
Reply #2 - Oct 21st, 2002, 3:14pm
I agree with Ken.  I think that we're a long way away from having truly soft analog IP.  However, I think that hard analog IP does make sense today, and I think that there are opportunities for "firm" analog IP today as well to gain some of the advantages of re-use.
Chapter 8 of
  • H. Chang, L. Cooke, M. Hunt, G. Martin, A. McNelly, L. Todd, Surviving the SoC Revolution, Kluwer Academic Publishers, 1999.
discusses some ideas on what firm and hard analog IP would be.
Also, you mentioned the VSI in general.  Just to be certain, I think that the most applicable specification would be the "Analog/Mixed-Signal Extension Version 2 (AMS 1 2.x)".  This describes in detail what an IP provider of hard analog IP would have to deliver to an IP integrator for the IP integrator to be successful.  I believe that even if one went with "firm" IP, that ultimately the delivery of it to a mostly digital SoC would require that it be delivered as "hard" IP and thus this specification would still be applicable in part or in whole.
-Henry
jbdavid
Reply #3 - Oct 2nd, 2005, 5:31pm
Take a look at "Systematic Design of Analog IP Blocks" J. Vandenbussche, G. Gielen, M. Steyaert..
They describe some approaches like you are talking about.. but the circuits they use are quite amenable to automated methodology for re-layout which is a much smaller class than "circuits I want to use"..
Jbd
jbdavid
Reply #4 - Aug 8th, 2006, 3:14pm
Hard macros are a proven viable methodology in IP re-use.
Even there, you run into problems with noise in the applications environwement.
Design re-use across foundry processes is generally not viable for analog designs.
Too many changes in subtle things mess the process up.
Jerry
