Dec 16th, 2025, 9:27pm
HSpice .PRobe (Read 7012 times)
i_mudra
HSpice .PRobe
Feb 12th, 2003, 12:49am
Can tell me anyone how I can see with AvantWaves (Hspice) a node from specific subcircuit using .PROBE command?
It's possible?
Thank You,
Regards ???
Re: HSpice .PRobe
Reply #1 - Apr 30th, 2003, 8:14am
How about:
.PROBE V(I1.I2.I3.NODENAME)
I1 is the top level instance, and then I2 is the instance
inside that subckt, and I3 inside that subckt and
finally NODENAME as the net name inside the I3 subcircuit.
So you give a path of instance names down through the
hierarchy.
