Jul 6th, 2025, 5:07pm
convolution of  two time functions in Pspice (Read 4114 times)
abhay
Feb 18th, 2003, 1:10pm
Hi Experts,
Is there a way to convolute two time functions in PSpice? I think we can use the ABM functions in PSpice but could  not come up with a suitable implementation.
thanks
-abhay
View Profile apteabhay   IP Logged
Eugene
Re: convolution of  two time functions in Pspice
Reply #1 - Feb 18th, 2003, 7:05pm
If you have access to VerilogA I believe you can convolve two time functions using a pwl source and a z-domain filter. The pwl source pulls in one time function and drives the z-domain filter. The z-domain filter is an FIR filter with the taps equal to the time-domain samples of the second time function. The only thing not ideal about this approach is the first order hold introduced by the pwl source but if the sampling rate is high enough that should be irrelevant.
If you do not have access to z-domain block, I guess you could fit a filter to the Fourier transform of second time function and replace the z-domain block with that filter.
