Jun 30th, 2025, 11:43pm
THD, SNR, & Noise Measurement of filter (Read 3934 times)
RC
Apr 13th, 2003, 10:18pm
I need to measure the THD, SNR, and Noise performance of a filter.
It is a low-pass filter with 10MHz cut-off frequency.
My doubts are:
1. how to measure the THD? using Signal Analyzer/Spectrum Analyzer. what input signal level, signal frequency I should use? upto what hormonics the THD should be taken into account?
2. how to measure noise? short the input to ground? or noise source needed? may I use 50Ohm resistor?
3. SNR? may I take the output foundamental to noise floor???
Thanks.
