Jul 20th, 2024, 6:22am
Porting HSpice .print statement to Spectre (Read 11039 times)
Eric_Gamble
May 01st, 2003, 11:06am
I am working on porting a data extraction script from HSpice to Spectre and am having difficulty finding the analog of the .PRINT statement in HSPICE.
Particularly, my application is something like this (simplified):
* Data
.DATA parameter_sweep M1_l M1_w M1_mx M1_my vds vgs vsb
+       0.5e-06 4e-06 1 1 0.05 0.5 0
+       0.5e-06 4e-06 1 1 0.05 0.5 0.3
+       0.6e-06 6e-06 1 1 0.075 0.6 0
+       0.6e-06 6e-06 1 1 0.075 0.6 0.3
.enddata
* Spice Netlist
M1 d g s b nch  L='M1_l'  W='M1_w'
vgs g s 'vgs'
vds d s 'vds'
vsb s 0 'vsb'
vbg b 0 0
* Simulation
.dc DATA=parameter_sweep
* Measure the parameters
.print dc
+ id=par('abs(lx4(m1))')
+ vt=par('abs(lv9(m1))')
+ gm=par('abs(lx7(m1))')
.end
currently, my Spectre deck looks something like this:
simulator lang=spectre
parameters m1_w=4.0e-6
parameters m1_l=0.5e-6
parameters  vgs=0.5
parameters  vds=0.05
parameters  vsb=0.0
datasweep paramset {
   m1_l    m1_l  vds   vgs   vsb
   0.5e-06 4e-06 0.05  0.5   0
   0.5e-06 4e-06 0.05  0.5   0.3
   0.6e-06 6e-06 0.075 0.6   0
   0.6e-06 6e-06 0.075 0.6   0.3
m1 (d g s b)  nch l=0.5e-6 w=4e-6
vsrc_gs g s vsource dc=vgs type=dc
vsrc_ds d s vsource dc=vds type=dc
vsrc_s0 s 0 vsource dc=vsb type=dc
vsrc_bg b 0 vsource dc=0   type=dc
swp1 sweep paramset=datasweep  {
      dc info where=logfile
This seems to print the operating point info from the first data point 4 times.  I don't whether this is simulating with the different parameters,and I don't know how to print specific values in Spectre.
I also would like to specify an output file for the data.
Can anyone help me out?
Eric.
Mighty Mouse
Here I come to save
the day!
Fantasyland
Re: Porting HSpice .print statement to Spectre
Reply #1 - May 7th, 2003, 5:45pm
Eric,
In Spectre version 5.0 and beyond you can use MDL to print. I suggest that you take a look at the SpectreMDL users guide to get a feeling for MDL, since there is a lot it can do.
Here is what I did to run your example. First, here is the netlist (a file named netlist):
// Example of sweeping and printing
parameters m1_l=0.5u m1_w=4u m1_mx=1 m1_my=1 vds_S1=0.05 vgs_S1=0.5 vsb_S1=0
model nch mos1 type=n
parameter_sweep paramset {
    m1_l	  m1_w    m1_mx   m1_my   vds_S1  vgs_S1  vsb_S1
m1  (d g s b) nch l=m1_l w=m1_w
vgs (g s) vsource dc=vgs_S1
vds (d s) vsource dc=vds_S1
vsb (s 0) vsource dc=vsb_S1
vbg (b 0) vsource dc=0
save m1:oppoint
Then I created an MDL file that describes the analyes and expressions that you want Spectre to evaluate (a file named netlist.mdl):
alias measurement dcrun {
	  run  dc
	  export real id=abs(I(m1:1))
//	export real vt=abs(m1:vt)
//	export real gm=abs(m1:gm)
foreach parameter_sweep {
	  run dcrun as dcrun1
Unfortunately, MDL does not yet allow you access to the operating point parameters (vt and gm). That is why they are commented out.
Finally, I ran the simulation using
spectremdl -design netlist
It put the printed results in netlist.measure. spectremdl is a perl script,  so you can modify it to change the way things are printed.
- MM -
Eric_Gamble
Reply #2 - May 8th, 2003, 3:58pm
Thank you MM,
 Your example does a good job of demonstrating the use of SpectreMDL.  Unfortunately, this particular simulation is not very interesting without being able to look at the operating point parameters.
 I am able to access the operating point data from ocean, so I'm writing a script to post-process the data and print it to a file.
Eric.
Julian18
Reply #3 - May 30th, 2007, 11:29pm
Eric_Gamble wrote on May 8th, 2003, 3:58pm:
Thank you MM,
Eric.
Hi, Eric
    How to write scripts to get access to the operating point data from OCEAN?
Reply #4 - Aug 20th, 2007, 8:47pm
Hi guys,
That is interesting. Sometimes I measure some parameters in HSPICE. An example is shown below. Can I do the similar thing in spectre?
.probe tran
Yawei
Scott Flinchbaugh
Reply #5 - Aug 21st, 2007, 8:37pm
Eric,
The .print statement is supported in Spectre as of the Spectre 6.0 release.
To insert a spice language statement in a Spectre netlist please use the following:
simulator lang = spice
.print V(out)
simulator lang = spectre
<spectre statements>
The same thing can be done with MDL, but only in later versions.  Please take a look at
your SpectreMDL user's guide.  With MDL strict spice print output file is not produced, rather
you can use a free format file with the use of the MDL fmt() statement.
-scott F.
View Profile flinchba   IP Logged
Scott Flinchbaugh
Reply #6 - Aug 21st, 2007, 8:39pm
Yawei,
Similar to the .print syntax that is now recognized by Spectre after 6.0, the same can be done with
the .probe statement.
-scott
John O Donovan
San Jose, CA
Reply #7 - Aug 28th, 2007, 5:03am
Also the operating point parameters should be accessible using the dev:param syntax. First check the name of the parameter by using 'spectre -h mos1' or bsim3v3, bsim4, ... All input, output and oppoint parameters should be accessible. If you can access it via Ocean, it should be accessible via MDL too.
 John
