Yes, for this purpose it is rather annoying.
There's a relatively simple workaround for the generators though.
Place an instance of the signal generator in a schematic, and run a normal transient analysis.
Then use the printvs function in the calculator on the output of the block (don't use start, stop and step in the printvs form), and then use File->Print to save the output data to a file.
You can then use a vsource with type pwl (or vpwlf), or port with source type pwl, to read the data you saved in the previous sim and use that in an envlp analysis.
A bit of a hack, bit it works.
I believe there is an initiative to solve the hidden state problem (probably by fixing the models in the short term) .
