Note, if you don't mind hacking the kit, then this will be a case of modifying the CDF (Tools->CDF->Edit CDF) for the appropriate component, selecting the component, going to the m parameter in the parameters section and changing the editability (I'm guessing here, but I'd have thought that would do it).
