Jul 19th, 2024, 11:09am
how to use the M factor for bjt's (Read 4492 times)
halvoth
Norway
May 20th, 2003, 6:21am
I need to change the m factor for my bipolar transistor. I run analog design environment 4.4.6 and AMS HIT-KIT 3.50 (---I use the 0.35uBiCMOS process).
The M field is disabled for my bjt's; I have to manually change the netlist to use other m factors.
Does anyone know how to enable the m-field for the bjt's ?????
thomas
Re: how to use the M factor for bjt's
Reply #1 - May 27th, 2003, 10:02pm
Contact the kit provider and ask them to enable it.
The workaround you mentioned on comp.cad.cadence
of using M1<0:4> to represent m=5 is rather less
efficient for the simulator, and VirtuosoXL can automatically
handle splitting the device based on the m-factor (which
is the reason that AMS have removed the ability to change
the m factor).
Reply #2 - May 27th, 2003, 10:04pm
Note, if you don't mind hacking the kit, then this will be
a case of modifying the CDF (Tools->CDF->Edit CDF)
for the appropriate component, selecting the
component, going to the m parameter in the parameters
section and changing the editability (I'm guessing here,
but I'd have thought that would do it).
