Jul 5th, 2025, 6:10pm
LNA Gain Measurement:No Convergence problem (Read 5037 times)
ravigupta
Austin,Texas
Jun 22nd, 2003, 1:03am
Hi ..
I have been trying to plot the voltage gain of the LNA , but I get an error:
"Convergence  difficulties resulted in error requirements being unsatisfied"
and so the simulation goes on indefinitely.
From the cadence documentation I found that this might occur if there are multiple periodic stimuli and their stimulus frequencies are not co periodic (and multiple of PSS analysis period).But I just have one voltage source in my circuit.(the circuit is the same as page 289 of "The Design of Cmos  RF Integrated circuits"by Thomas Lee").
Can anyone suggest what might be the cause of no convergence ?
Also,a very fundamental question , does the PSS analysis period correspond to the fundamental frequency of the source we use ?
Thanx,
Ravi
View Profile toravigupta   IP Logged
Mighty Mouse
Here I come to save
the day!
Fantasyland
Re: LNA Gain Measurement:No Convergence problem
Reply #1 - Jun 24th, 2003, 12:58am
Ravi,
For LNAs the PSS period should be the same as the period of the driving source.
It is hard to determine what is going wrong with your simulation from the description you have given. Does Spectre transient analysis run okay on your circuit?
- MM -
ravi gupta
Guest
Reply #2 - Jun 29th, 2003, 12:24am
thanx mm ,
the problem was solved when i reduced the tolerance in the pss options..
the simulator itself gave options like :check if my model parameters are correct ...
check if reltol etc are too tight ..
it pointed out the nodes where the tolerances were exceeded  .
thanx,
ravi
  IP Logged
