The noise goes to zero asymptotically? Are you sure you are using the time-domain noise feature? If so, could you tell me what T is and what are the start and stop frequencies for your time-domain noise analysis.
Concerning the two different interpretations of the time-domain noise feature, the one I give in my paper is more correct. The problem with the "its the noise at a single time point" interpretation is that it consists only of the values at a single point in time. As such, there is no "signal", i. e., a value that varies with time, and so there is no PSD.
