Mighty Mouse
![](http://www.designers-guide.org/Images/mightym.gif)
Here I come to save the day!
Fantasyland
Drive the port for which you want the impedance with 1 A current source and perform an AC analysis. Then plot the port voltage. The impedance is V/I, and I is 1, so the magnitude and phase of the voltage will be identical to the magnitude and phase of the port impedance.
- MM -
