Sorry, I never got around to writing this up - it seemed a little pointless since IC446 is no longer supported, and eyeDiagram is available as a special function in IC50 onwards.
So my recommendation is to use IC5033 or IC5141 which have this function built in. Also, wavescan (the new waveform tool) has the ability to do this natively (double-click on the x-axis, and you can tell it the period to do the eye-diagram over).
