May 5th, 2024, 10:14am
Simulating a PolyPhase Filter in SpectreRF (Read 59 times)
jstenger
Oct 06th, 2003, 2:58pm
How do I simulate a polyphase filter with SpectreRF and take advantage of the Direct Plot features available in ADE?
That is, how do I generate a 90 degree phase shift of a signal over a wideband frequency range, with unity gain?  The purpose of this is to do Noise Figure and IPN calculations with ADE from SpectreRF results.
Here is the background information to assist in answering this question.
For those not familiar, a polyphase filter (complex filter) requires In-Phase and Quadrature inputs.  The basic idea is to design a low-pass filter and cross-couple the I and Q channels to each other through the appropriate impedances.  The end result is a low-pass filter shifted in frequency to the desired IF (intermediate frequency).  One benefit of this architecture is the image suppression at the negative IF.
Thank You,
Re: Simulating a PolyPhase Filter in SpectreRF
Reply #1 - Oct 8th, 2003, 12:58am
In transient or PSS, you specify quadrature inputs using the sinephase argument
Vi (i 0) vsource type=sine freq=FREQ ampl=1 sinephase=0
Vq (q 0) vsource type=sine freq=FREQ ampl=1 sinephase=90
FREQ would be a design variable that you could sweep.
For small signal analysis, you could use the phase or pacphase parameter
Vi (i 0) vsource mag=1 phase=0
Vq(q 0) vsource mag=1 pahse=90
