forghani
I have a question about the effect of circuit parameters' change in monte carlo simulation. Suppose I simulate a circuit for 100 times, and I see an unordinary situation in run 8. Then I change a transistor parameter or a currrent source value (no change in the topology). Afterthat, I run the monte carlo simulation again like the first experiment.
1. Is the randomness in both experiments the same? 2. If the randomness does not remain the same, what I can do to make the randomness the same and then run the monte carlo only for the run that had a problem after the circuit modifications, to see if I have solved the circuit problem?
Sincerely,
Pooya
