Jul 16th, 2024, 2:51pm
trans analysis convergence difficulties in spectre (Read 11303 times)
tulip
Nov 11th, 2003, 12:59am
my circuit is a high frequency mixer(LO:1.5G, RF: 1.3G) circuit.
when simulated with transient analysis, spectre report " convergnence difficulties resulted in error requirements being unsatisfied."
"zero diagonal found in Jacobian at 'I0.I51.C0.1" and 'I0._net3",
I tried serveral methods, such as using gears method,
set gmin to 1e-18, set cmin to 1f, and set the maxstep,
but convergence difficulties still exit.
How can I slove this problem?
many thanks!  :)
Re: trans analysis convergence difficulties in spe
Reply #1 - Nov 11th, 2003, 9:08pm
Spectre is telling you that there is a problem at 'I0.I51.C0.1" and 'I0._net3". There is some problem such as a floating node or loop of shorts there. When you look in that area, what do you find?
tulip
Reply #2 - Nov 12th, 2003, 12:54am
I changed my circuit a little. Now it do not report"zero diagonal found in Jacobian at 'I0.I51.C0.1" and 'I0._net3", but it still report" convergence difficulties resulted in error requirements being unsatisfied".
when I change the simulation option from conservative to moderate, the warning message disappears.
when I run the PSS analysis, the convergence problem still exits, and the circuit simulation stops before it get the results.
Reply #3 - Nov 12th, 2003, 9:15am
It seems as if the basic problem still exists. There appears to be some problem in the circuit or with a model near  'I0.I51.C0.1" and 'I0._net3". When you look in that area, what do you find?
Venkatesh TS
Guest
Reply #4 - Dec 29th, 2005, 7:15pm
      i'm also facing exact same issue. Spectre says
"Warning from spectre at time = 2.5016 ns during transient analysis `tran'.
   Convergence difficulties resulted in error requirements being unsatisfied."
What to do?
  IP Logged
Reply #5 - Dec 30th, 2005, 9:45am
The message "Convergence difficulties resulted in error requirements being unsatisfied." indicates that Spectre could not take a time step small enough to maintain accuracy because of convergence problems. This implies that there is some problem in the circuit that only becomes exposed with small time steps. Typically, this happens when there are discontinuities in the capacitors. With large time steps (long time periods) the capacitors are diluted with the resistive portion of the circuit. But with very small time steps the capacitive part of the circuit dominates. In the extreme, with very small time steps, the effect of the resistive portion almost disappears. In this case, the capactive part of the circuit must be simulatable by itself. Thus, the capacitor models must all be continuous and there must be capacitive paths from all nodes to ground.
You can often circumvent this problem using cmin, which adds a capacitor from every node to ground, which provides the capacitive path to ground and tends to smooth the discontinuities.
