Hi....
I have a problem with my ckt.
My ckt is some sort of mixed signal ckt. it is a fully differential opamp with Switched cap CMFB.
I want to test its slewing rate and its settling time.
Therefore i connected my ckt in the same configuration as suggested in the
http://www.designers-guide.com/Analysis/diff.pdfbut the problem is the conventional trans analysis could not be used since there are also two clocks incorporated.
I have also read that PSS can do it. is it true? would you suggest the simulation setup i can use? e.g. the tstab, tstart, etc.
Thanks a lot.
ps: fyi, my opamp specification is 100dB gain
![Shocked Shocked](https://designers-guide.org/forum/Templates/Forum/default/shocked.gif)
, 150MHz GBW.
