Aug 15th, 2024, 11:32pm
cmfb stabilization (Read 6996 times)
Neha Bhargava
Guest
cmfb stabilization
Dec 19th, 2003, 3:09am
Hi ...
I've designed a fully differential folded cacode opamp with continuous time cmfb.The cmfb compares the output common mode with reference and applies correction to the bias of tail current source of input differential pair.
I am not able to stabilize the cmfb loop.It gives high frequency oscillations 100MHz.
Can anyone tell what are the compensation tech. used?
Thankyou so much
Neha
  IP Logged
Paul
Switzerland
Re: cmfb stabilization
Reply #1 - Dec 21st, 2003, 10:44am
Hi Neha,
as for the differential path, you should check the phase margin of your common-mode amplifier through AC simulations. What margin do you see?
I would also suggest to apply the feed-back not to the tail current, but to the current sources in the output branches. It is preferrable not to move around the source of the differential pair.
Paul
b_neha
India
Reply #2 - Dec 21st, 2003, 9:41pm
Hi Paul,
If Acms is gain in sense circuit and Acmc is gain in common mode control, the forward gain in CMFB loop will be Acms*Acmc.
The lf gain for this is 85dB, and phase=180 degrees.
The phase decreases from 180 degrees to negative values at high freq.
The freq at which phase is 0 deg. while gain is still >1 is 2MHz.
But I'm getting oscillations at 84 MHz.
Neha
Paul
Switzerland
Reply #3 - Dec 25th, 2003, 1:51pm
Neha,
having a gain>1 at 0 deg phase shift is a bad sign for stability. But it is not yet clear why your oscillations occur at much higher frequencies. Can you give more informations on the input signals of your amplifier in this transient simulation (differential input signal, common-mode input level, output load, feed-back type), please?
Paul
rajath
Reply #4 - Feb 2nd, 2004, 4:57pm
Neha,
From your post it's obvious that the Phase margin is
less than zero at 0dB gain, which is an obvious sign of instability. A phase margin of at least 45 degrees is needed for a stable transient response.  If your load
and process variations are tightly controlled you can get away with a PM of around 20-30 degrees.
I'm still not sure about one thing though: What frequency will a circuit having a negative phase margin oscillate at? Is it the unity gain frequency?
rajath
