Nov 7th, 2026, 9:20am
IIP3 and IIP2 Simulation in SPECTRE (Read 9984 times)
junkwar2003
WA
Jan 16th, 2004, 6:07pm
I have tried using PSS/PAC mentioned in the design guide to compute the IIP3 and IIP2 for a mixer. It works however I have a problem. My RF freq is at 5.6 GHz and the LO is at 2.8GHz with IF at DC. To get simulation to give meaningful results you would want the second tone that PAC places at least a 1-2 MHz away from the RF i think. The problem is the beat frequency that can be a integer multiple of all freq in the system is around 1 MHz or so when running PSS simulation. This takes hugh amount of time since # of harmonic is increased. I tried it and basically simulation crashed claming insufficient memory. Is there a better way to get IIP3 and IIP3 values using SPECTRE. I have new to SPECTRE so any help would help. Thanks
Jitter Man
Am I? Or am I so
sane that u just
blew your mind?
Re: IIP3 and IIP2 Simulation in SPECTRE
Reply #1 - Jan 16th, 2004, 9:59pm
Junkwar,
Rather than using PSS as your base analysis, use QPSS. It will allow you to place your output frequency as close to zero as you like without penalty.
Having said this, I would like to suggest a possible solution that is even more efficient. Say you were able to perform the analysis using PSS with a 1MHz output frequency. Then consider what would happen to the result if you changed the output frequency to 100KHz. If the circuit bandwidth is much greater than 1MHz, the results should not change much. Now consider shifting the frequency to 10KHz, 1KHz, 100Hz, 10Hz, 1Hz. The results for all of them should be the same, right? Here is where it gets interesting. Why not take it down to 0Hz? In concept this works, but if you tried this on the lab bench you would not be able to resolve the distortion product at DC from the other signals present at DC (offsets, biases, etc.). But when simulating with Spectre using the procedure outlined in the paper, you get the distortion product out separately from the other DC components. So, while I have not tried it, I believe you could use a 2.8GHz PSS analysis with the large RF at 5.6GHz, the small RF at 5.6GHz, and the LO at 2.8GHz. The output intermodulation distortion would be in the -2 sideband. This approach would be very fast as it would be the same cost as a single-tone PSS+PAC analysis.
Jitter Man
junkwar2003
WA
Reply #2 - Jan 16th, 2004, 10:22pm
Thanks Jitterman,
  Unfortunately we do not have SPECTRE RF just spectre so there is no QPSS function. I have tried the other method but that does not work well for IIp3 sims. I am almost thinking about moving to ADS and using harmonic balance simulation for faster results.
Parag
Jitter Man
Am I? Or am I so
sane that u just
blew your mind?
Reply #3 - Jan 16th, 2004, 10:31pm
If you have PSS or PAC, you have SpectreRF. If you do not have QPSS, then you have a really old version of SpectreRF and you should upgrade.
Jitter Man
junkwar2003
WA
Reply #4 - Jan 31st, 2004, 12:32pm
Another questions. I tired to find some guide on how to use QPSS to measure IIPn measurements but I have not found it. Do you use the same technique as pss/pac? I have upgraded our spectre so now we have qpss and qpac. Another problem I saw as the for QPSS all signals have to be classified as Large and in the  QPAC you can only specify one signal as large and rest as moderate. I have two large LO signals and one RF. Thanks
Jitter Man
Am I? Or am I so
sane that u just
blew your mind?
Reply #5 - Jan 31st, 2004, 5:02pm
Parag,
You have two LOs? There are two frequency conversion stages? I recommend that you just try it with one first. The procedure is basically the same as with PSS/PAC. Simply use QPSS and QPAC instead. In this case, the LO would be the large tone, the large RF tone would be the moderate tone, and the small RF tone is applied in QPAC.
- Jitter Man -
