Aug 14th, 2024, 12:18pm
PLL Based Frequency Synthesizers (Read 3181 times)
atharapi
Jan 27th, 2004, 9:16pm
I am doing a frequency synthesizer design in Cadence and am just starting out.
What are the best resources to figure out how to measure phase noise of the entire synthesizer, using Cadence ?  Does one use Spectre ? HSpice ? How does one get started ?
Any help would be appreciated.
August West
I'll get up and fly
away
Re: PLL Based Frequency Synthesizers
Reply #1 - Jan 28th, 2004, 2:24pm
If you are interested in the effect of device noise on the phase noise, SpectreRF is essential. HSPICE is not capable of doing a noise analysis when large signals are present and so in this case is worthless. Even if you are interested in studying the effect of noise coupling, either through the supplies or through the substrate, SpectreRF is the best choice because it provides the PAC/PXF small-signal analyses that can compute the transfer functions of circuits in the presence of large signals. So you would compute the output noise by multiplying the input noise by the transfer function.
For coupling, it is also possible to do brute-force transient simulation, in which case HSPICE could be used, but Spectre would be a better choice. It is very tough to control errors in HSPICE, and this particular simulation would have to be performed with the errors carefully controlled because the interferring signals are small.
For a reference, try http://www.designers-guide.com/Analysis/PLLnoise+jitter.pdf. It is long, but it has a lot of information.
-August
