Jul 16th, 2024, 1:40am
Missing hdl.var!!Why? (Read 145 times)
Aigneryu
Feb 18th, 2004, 9:03pm
I tried to open a new verilogams view in the lib manager of cadence design environment.
but when I saved the edited netlist file,  an error message showed up and told me that "parsing of verilog-ams files produced warnings..."
and then I was told that "ncvlog : *W, DLNOHV : Unable to find a 'hdl.var' file to load in ".
what does it means?
I checked the folder of the cell, there was no hdl.var.
Re: Missing hdl.var!!Why?
Reply #1 - Mar 4th, 2004, 10:17am
Generally with AMS Designer (along with the digital simulation tools, such as ncvlog, ncsim etc) it requires you to have
an hdl.var file in one of a number of search locations
(typically your working directory).
You don't need that much in it. Usually something like
this will suffice:
SOFTINCLUDE $AMSHOME/inca/files/hdl.var
# setup use5x by default
define ncuse5x
define cdslib ./cds.lib
You might set up the path to transistor models if you're
simulating at transistor level, although this can be
done through the UI now with AMS Designer.
