Eugene
It sounds like you are using a voltage domain model, one that simulates VCO output voltage. If so, why not try a phase domain model, one that simulates VCO phase? Or better yet, I would try a model that simulates VCO frequency. You can still include the sigma delta modulator in detail as well as quantization. The model will run 100-1000 times faster and require much less disk space. The trick is to move the VCO integrator and reference integrator into the PFD model. Moving the integrator seems counter intuitive when you try to move the integrator through the fraction-n divider but if you think about it, it makes sense. When the divider ratio changes, the phase of the divider does not instantaneously change. The effect of the new divide ratio does not occur until a counter hits the new limit. The sigma delta output effectively goes through an integration too and that integrator can also be moved to the PFD [1]. Moving the integrator to the PFD has another advantage: it gives the PFD memory, memory which can be used to model cycle cycle slips by making the integrator resettable [2]. I hope this helps.
[1] Michael Perrott, Mitchell Trott, Charles Sodini. "A Modeling Approach for Sigma-Delta Fractional-N Frequency Synthesizer Allowing Straightforward Noise Analysis". IEEE Journal of Solid-State Circuits. Vol 37. Aug 2002.
[2] Analog and Mixed-Signal Hardware Description Languages. Edited by Alain Vachoux, Jean-Michel Berge, Oz Levia and Jacques Rouillard. Chapter 5: Non-linear State Space Averaged Modeling of a 3-State Digital Phase Frequency Detector.
