Hi, Mighty Mouse,
SpectreRF is a harmonic simulator. Does it suit to simulate inverter? I thought SpectreRF is more suitable for RF circuit.
zteic,
Are you a IC designer from ZTE? ;) Just a guess. The noise parameters in SPICE model are used for .noise analysis which always acompanies AC analysis. So you can not see any jitter due to random noise in a transient analysis.
But if you want to analyze data dependent jitter (ISI) of your inverter, apply a stimulus with a data pattern such as 10111101000001.... Then sweep the start time of the data patten.
I hope it is helpful.
Yawei Guo
