Dec 13th, 2025, 8:17pm
Poll Poll
Question: Gaussian Distribution in VHDL
RANDOM NUMBER GENERATOR IN VHDL
POISSON DISTRIBUTION IN VHDL
« Created by: Anne123 on: Mar 10th, 2014, 2:03am »
Random Number Generator.. (Read 2011 times)
rockeagle_11
Mar 8th, 2004, 5:22pm
hi.. i m trying to write a vhdl source code using 2 7-segements to randomly output numbers from 1 to 45..
can anyone help me in this..thx!!
Amrsfmt
change over
Egypt
Re: Random Number Generator..
Reply #1 - Mar 20th, 2006, 12:45pm
hi,
there is a function in the IEEE.MATH_REAL named uniform that generate uniform distributed random values from 0.0 to 1.0. you can use it.
if you want to make anyother distributions like gaussian, you will have to use an algorithm that convert uniform to the other distribution.
I have implemented the gaussian distribution in VHDL-AMS code.
here it is:
-- Implementing a gaussian random number generator.
-- procedure gaussian_pos(variable SEED1,SEED2:inout POSITIVE;variable mu,sigma:in  REAL;variable X:out REAL)
-- procedure gaussian(variable SEED1,SEED2:inout POSITIVE;variable mu,sigma:in  REAL;variable X:out REAL)
-- 		Purpose:
--				- For gaussian_pos:
--	   			Returns, in X, a pseudo-random number with gaussian
--	   			distribution in the open interval (mu , 4*sigma+mu).
--				- For gaussian:
--	   			distribution in the open interval (-4*sigma+mu , 4*sigma+mu).
-- 		Special values:
--	   		None
-- 		Domain:
--	   		1 <= SEED1 <= 2147483562; 1 <= SEED2 <= 2147483398;sigma > 0.0
-- 		Error conditions:
--	   		Error if SEED1 or SEED2 outside of valid domain, and sigma < 0.0
-- 		Range of Output:
--	   			mu < X < 4.0 * sigma + mu
--	   			mu - 4.0 * sigma < X < 4.0 * sigma + mu
-- 		Notes:
--	a) The semantics for this function are described by the
--	algorithm published by Richard Saucier in "Computer Generation
-- 		of Statistical Distributions,",From the Army Research Laboratory
--	The algorithm is based on using 2 uniformly distributed
--		random numbers and looping on them to generate another
--		random number with gaussian dsistribution.
-- 		b) Before the first call to gaussian, the seed values
--     	(SEED1, SEED2) have to be initialized to values in the range
--     	[1, 2147483562] and [1, 2147483398] respectively.  The
--     	seed values are modified after each call to gaussian inside the
--		uniform function call.
--		c) gaussian_pos doubles the probablity of the postive part of the
--			gaussian distribution curve, because it takes the samples of
--			negative side and move it to the positive side.
-- Declaring Package
package Maths is
	procedure gaussian_pos(variable SEED1,SEED2:inout POSITIVE;variable mu,sigma:in REAL; variable X:out REAL);
	procedure gaussian(variable SEED1,SEED2:inout POSITIVE;variable mu,sigma:in REAL; variable X:out REAL);
end package Maths;
-- Library used
library IEEE;
use IEEE.MATH_REAL.all;
-- Implementation
package body Maths is
-- Implementing gaussian_pos
procedure gaussian_pos(variable SEED1,SEED2:inout POSITIVE;variable mu,sigma:in REAL; variable X:out REAL) is
	-- Variables needed for calculations
	variable x1:REAL:= 0.0;
	variable x2:REAL:= 0.0;
	variable temp:REAL:= 2.0;
	variable tempdiv:REAL:= 0.0;
	constant max_div:REAL:= 4.0 * sigma;
begin
	-- loop untill we get
	while temp > 1.0 loop
		-- Generating 2 unifrom random variables
		uniform(SEED1,SEED2,x1);
		uniform(SEED1,SEED2,X2);
		-- temp = x1^2+ x2^2
		temp := x1 * x1 + x2 * x2;
	end loop;
	-- Calculating output
	tempdiv := sigma * x1 * sqrt(-2.0 * log(temp)/temp);
	-- checking that value in the range of output and moving negative
	-- side to positive side.
	if ((tempdiv > max_div) or (tempdiv < -max_div)) then
		X := mu + max_div;
	elsif ((tempdiv < 0.0) and (tempdiv > -max_div)) then
		X := mu - tempdiv;
	else
		X := mu + tempdiv;
	end if;
end procedure gaussian_pos;
procedure gaussian(variable SEED1,SEED2:inout POSITIVE;variable mu,sigma:in REAL; variable X:out REAL) is
begin
	end loop;
	if (tempdiv > max_div) then
		X := mu + max_div;
	elsif (tempdiv < - max_div) then
		X := mu - max_div;
	else
		X := mu + tempdiv;
	end if;
end procedure gaussian;
end package body Maths;
Thank you,
Amrsfmt
Solve this out
Anne123
Reply #2 - Mar 10th, 2014, 2:03am
Thank you very much for theh Random Number generator code . I am new to VHDL my boss asked me to implement Gaussian and Poisson distribution in VHDL . I want to know whether i can use the same logic in VHDL if so what are the additional packages I should add?
Thanks & regards,
Anne123
