I am designing a S/H circuitry with bootstrapped MOS switch. As well known, linearity is very important for S/H.
When I simulating the S/H circuitry using HSPICE, one sine waveform is applied to the input of S/H. Then the S/H gives an output waveform of first-order sample and hold, i.e., track and hold. FFT analysis is done for the output of S/H.
Because usually S/H is used as the frist stage of a pipelined ADC or other A2D converters. The A2D converter only samples the output of S/H when the S/H is in hold phase. What the output of S/H looks like is not important in the sample phase of S/H. I suspect whether I should put another S/H suceeding the first S/H to get a waveform much like zero-order sample and hold.
Would you please give me any advices?
Thanks in advance.
Yawei Guo
