Jimmy,
Unfortunately it can't be turned off right now. There's a PCR for this:
PCR: 482903 Title: Parametric Analysis output window should stay iconified
Also, it should take note of having auto-update off (covered in the same PCR).
If you contact Cadence via your normal support channel, then additional customers who are asking for this to be fixed will influence the priority for getting this minor irritation fixed.
