Aug 15th, 2024, 10:54am
To measure lock time of PLL (Read 13134 times)
sachinkr
Sangli
Mar 14th, 2004, 1:01pm
I am doing simulation of PLL frequency synthesizer in transient analysis using SpectreRF to find lock time and to see other signal condition. The problem is that the simualtion is taking very large time and memory. The same problem for PSS and PNoise analysis. Can anybody tell me alternative of this or any suggestion?
sachin
August West
I'll get up and fly
away
Re: To measure lock time of PLL
Reply #1 - Mar 14th, 2004, 8:39pm
Sachin,
   You haven't given us much to work with. Do you believe the simulation time is excessive? If so, why? How big is the circuit? What are the clock rates? How many time steps is it taking? What kind of machine are you using? How heavily is the machine loaded? You say it takes a lot of memory, do you mean physical memory or disk space? What tolerances are you using? Did you set the maximum time step? How many signals are you saving?
If you want help, you need to put some effort into describing the problem with sufficient detail so that someone has a chance of helping you.
-August
sachinkr
Sangli
Reply #2 - Mar 14th, 2004, 9:22pm
sorry for giving less information. I am working on PLL Frequency Synthesizer and i am using dual loop architecture. The operating freequency range for synthesizer is in ISM 902-926 MHz. I am using only on VCO for two loop and VCO tuning range is from 820MHz to 1 GHz with gain 28MHz/v. The input clock for first main loop is 125 KHz and for second loop 4 MHz. The second loop will set VCO frequency from 896 MHz to 926 MHz using 3-bit binary counter operating at 62.5 KHz
August West
I'll get up and fly
away
Reply #3 - Mar 15th, 2004, 11:06am
If you are trying to simulate 1GHz and 67kHz signals in the same circuit at the transistor level, the simulation is going to be slow. You can try using a reduced accuracy simulator, such as UltraSim. Or you could try abstracting the simulation to a higher level using Verilog-AMS.
-August
Reply #4 - Jun 26th, 2004, 11:16pm
But how to measure lock time in experiment? Is there anybody who could give me any reference?
Yawei
Eugene
Reply #5 - Jul 2nd, 2004, 11:37am
I guess the question about measuring lock time comes down to what you have access to in the lab. Can you observe the VCO input?
As for simulation, why do you want to simulate lock time with device level models?  Isn't lock time dominated by the basic functionality of the PLL blocks? The basic functionality of all blocks in the loop can be simulated much much faster with behavioral phase domain models.
Aigneryu
Reply #6 - Jul 31st, 2004, 1:14am
Dear ywguo,
You could find tutorials of measuring PLL setup time with kinds of instruments in the Natioanl Semiconductor Application Notes.
Hint: AN885,
You can simply use spectrum analyzer to measure setup time.
Set the span to 0Hz and maximize the video bandwidth.
Tommy
Guest
Reply #7 - Mar 3rd, 2005, 2:54am
[quote author=Eugene  link=1079298104/0#5 date=1088793439]I guess the question about measuring lock time comes down to what you have access to in the lab. Can you observe the VCO input?
As for simulation, why do you want to simulate lock time with device level models?  Isn't lock time dominated by the basic functionality of the PLL blocks? The basic functionality of all blocks in the loop can be simulated much much faster with behavioral phase domain models. [/quote]
Thanks Eugene,
I have been thinking on same lines. But how to proceed with a phase-domain pfd which models the initial lock up process of a PLL? The model in Ken's paper is for an (unwrapped?) phase less than 2pi.  would a simple wrapping of input phase difference to the PFD work???
Tommy
  IP Logged
Eugene
Reply #8 - Mar 4th, 2005, 8:46am
If you have access to SpectreRF, I think there's an appendix in the SpectreRF user's manual called "Introduction to the PLL Library", or something like that. The appendix includes a description of a phase domain model of a 3-state PFD. There are two fundamental steps in the derivation. First, you must pull the VCO and reference integrators into the PFD model. This saves on convergence errors and makes the DC analysis of the phase domain model linearize about frequency, which is something that has a meaningful equilibrium value. More importantly, this step gives the PFD memory, which is necessary to capture the hysteretic nature of the relationship between average output and phase error. Surprisingly, this step still works for fractional N PLLs because the sigma delta noise enters the loop linearly AFTER being integrated. Thus, for fractional Ns, you also absorb the sigma delta noise integrator into the PFD too. Now the PFD has memory and can accurately simulate cycle slips, which leads to the second fundamental step. Replace the integrator with a resettable integrator. As the integrator integrates frequency error to produce phase error, it resets at +-2Pi. The appendix describes a few other tricks but these two are the key steps.
Please note that Cadence was issued a patent for the PFD model. I am fairly sure that means you can use it from within the Cadence tool set. I am not sure what it means beyond that. I have enough trouble reading technical stuff, let alone technical stuff written in legalese.
Tommy
Guest
Reply #9 - Mar 6th, 2005, 5:51pm
Thanks a lot Eugene for your pointers. I will pursue it.
I found the paper you were referring to on Cadence website
www.cadence.com/whitepapers/pllapp_note.pdf
I guess the ideas are public & verilog-a code is only for Cadence users Smiley
Tommy
  IP Logged
Eugene
Reply #10 - Mar 6th, 2005, 6:55pm
No problem. I have used the PFD many times for large and small signal analysis. Let me know if you have any questions about it.
navin_kumar
Reply #11 - Aug 5th, 2005, 5:28am
IIN MY VIEW IT IS BETTER TO FAST THE LOOP AND SEE THE CONTROL VOLTAGE WAVE FORM ,THEN IT MIGHT NOT TAKE THAT MUCH TIME FOR SIMULATION
AND RUN THE SIMULATION FOR 10 TIMES WHERE  YOUR CONTROL VOLTAGE HAS SETTLED TO A SPECIFIED TOLLERENCE (RIPPLE) OR  UR FREQUENCY OF THE VCO WITHIN THE +/- DEVIATION.
