Jitter Man
Am I? Or am I so sane that u just blew your mind?
First make sure that your circuit produces a periodic response. If not, you need to change something, because SpectreRF will never converge on a circuit that does not produce a periodic response in steady state. Then set tstab sufficiently large. It may need to be as much as the settling time of the filter. Finally, if you tighten the tolerances, consider loosening them back to the default values.
