Sheela,
Try typing:
editor
in the CIW - it should be the name of some editor. You can set it to the editor of your choice by doing (say):
editor="nedit".
Now, it sounds from the fact that you're referring to ahdl.def that your code may be spectreHDL, not Verilog-A?
When you create the view, using File->New->CellView, you can choose one of two tools:
SpectreHDL-Editor Verilog-A-Editor
The viewName can be whatever you want, but people commonly use "ahdl" for SpectreHDL and "veriloga" for Verilog-A (that's what you've seen in ahdlLib). You don't need to write both spectreHDL and verilog-a, one would be sufficient (if you're running spectre). However, I'd recommend that if you're going to choose one, choose verilog-a, since that's the standard, and if you're going to use AMS Designer, spectreHDL is not supported there...
The fact that you're getting a licensing error suggests that the licenses aren't set up properly for that session. Try typing:
lic_error -24
and this will give you lots of details as how to figure out why the licenses can't be found. It will be trying to check the licenses in various parts of the tools, hence the error.
