Aug 16th, 2024, 10:16pm
Wide tuning range VCO design problem (Read 3611 times)
gggould
Guest
Apr 09th, 2004, 8:41pm
I am designing a VCO with varactor and switching cap to cover 800MHz wide. But I find that the VCO gain and amplitude variations are big problems. Both Kvco and output amplitude increase with the operating frequency...
Any tips or advices?
Thank you very much...
  IP Logged
wizz
Re: Wide tuning range VCO design problem
Reply #1 - Apr 12th, 2004, 8:51pm
To minimize Kvco variation, you could use a lot of switching bands. You'll find up to 8bits worth of bands in published VCO's if I'm not mistaken (which means you need to put in 256 swiched caps). Could be it was 6 bits, which would mean 64 switched capacitors.
And 800MHz tuning: doesn't say anything about difficulty; it's the percentage that counts. If you're trying to do 50-850MHz with one LC VCO I wish you good luck Smiley. If it is around 17GHz, it shouldn't be that hard....
wizz
Fei
Reply #2 - Apr 19th, 2004, 11:46am
The variation is caused by the "ON" resistance of the switch transistor.  There are a few things you can do to mitigate the effect:
1). Using a larger size transistor;
2). Using an additional cap in series to the switched cap tanks.
Hope it helps
Fei
